Problem with the template setting
i’ve installed the newspaper template and when i activate it after activated all required plugin i don’t have the drag and drop interface the texte look like this [vc_row][vc_column width="1/1"][td_block_trending_now sort="random_posts" limit="5" custom_title="FLASH INFO"  header_color="#AC0000" category_ids="354" ][td_block_big_grid_3 td_grid_style="td-grid-style-1" sort="a-la-une"][/vc_column]
like wordpress text view mode.
Please someone can help me to resolve my problem please
Thank you
Please read our documentation about tagdiv composer -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
Please make sure that you have the tagdiv composer activate.
Also please be notice that the TD Composer is just for pages, and create template with tagdiv Cloud Library
https://www.screencast.com/t/fnlQnXRo
or
https://www.screencast.com/t/SbbLzGI5h
Hello Calin,
Thank you for your reply.
All the required plugins that that template Newspaper want to work has been installed.
If you still have problems please provide more details and some screenshots.
thank you again for your help.
This are some screenshots.
Screenshot 1
Screenshot 2
Thank you
Your page is look like this because is made with tagDiv Composer, and is created with shortcodes, this is how suppose to look.
https://www.screencast.com/t/CixiUDkVdhM5
tagDiv Composer tutorial -> https://forum.tagdiv.com/tagdiv-composer-tutorial/
