Dear, I am having several problems with the topic. Post images are cropped even using the full option. I am not able to change the color of the menu bar, nor change the size of the title. I can’t seem to narrow the width of the advertising next to the title.
I noticed that some problems started to happen after uninstalling and reinstalling the theme. Please help me.
Hi Lucila,
Lets try to take the problems one by one:
1. Post images are cropped – The theme crop automatically the thumb size set in theme panel -> https://i.imgur.com/IJe27ab.png Each post style/template use a thumb dimension, this thumb is made by cropping the featured image.
If you choose to use a single post template from tagDiv Cloud Library, you can edit it using tagDiv Composer and choose the featured image size you want to use -> https://i.imgur.com/DHsb7ar.png
2. I am not able to change the color of the menu bar, nor change the size of the title -> you need to check if you are using a standard header (then you can use the options from theme panel -> https://i.imgur.com/t7g1mz0.png -> https://i.imgur.com/KE9Q5D5.png) or a cloud header, this can be edited with tagDiv Composer -> https://i.imgur.com/RILkoYd.png
3. The width of ad can be adjusted only with tagDiv Composer -> https://i.imgur.com/pWoHbjF.png (you can set 100$ from the column or less) also you can adjust the row width and layout from tagDiv Composer -> https://tagdiv.com/tagdiv-composer-page-builder-basics/
