Hi Guys,
I have a problem with the WP Editor in tagDiv Composer.
If I select “Add Element” -> “Text with title” -> “Edit Contant”, the WP Editor will open. But when I write a text in the WP Editor, it does not appear on the page. In the element on the page, only the placeholder text “HTML code here! Replace this … “is visible.
All other elements (including the tagDiv Cloud Library) work flawlessly.
I also disabled all unchecked plugins and restored a previous version when the WP Editor was still working. Everything without success.
Do you have a solution?
Thanks for your great work and support! You are doing a great job!
Regards
arti
I just noticed that in the mobile version, when loading a page, the search box appears short. You can see that on the video quite well.
https://drive.google.com/file/d/1b0gy3sOkZvMbEQL2w2zi1jsmv0Zz9yB_/view?usp=sharing
Can this be related to the first problem?
Many Thanks!
Regards
arti
Please make sure that you have the last version of Newspaper v9.2.2, ( there was some problem in older versions ) if not please make an update to the theme -> https://forum.tagdiv.com/how-to-update-the-theme-2/
