Hi, I’ve installed the theme and make a preview before activation but I have this error “Fatal error: Call to undefined method WP_Upgrader::clear_destination() in /home/xxxxxx/domains/sitename.it/public_html/wp-content/themes/Newspaper/includes/wp_booster/td_first_install.php on line 164”.
I’ve reinstalled the theme many times and installed (and activated) all plugins but the error is the same. I don’t know where is the problem!
Hello idazamp,
Make sure that you have installed the latest theme version via FTP way because this is the surest method in this case. I suggest you make a new fresh install via FTP with the latest version of the theme, according to our documentation here -> https://forum.tagdiv.com/install-via-ftp/
I’ve installed the new version 8.5 via FTP (included the plugins) but the error is the same. Now I have another error when I try to activated the theme:
Fatal error: Call to undefined function rest_url() in /home/xxxx/domains/sitename.it/public_html/wp-content/plugins/td-composer/includes/tdc_main.php on line
Hello idazamp,
Please keep in mind that before that the latest version of the theme to be released, it has been fully tested and we have not encountered this kind of error, sorry! Most likely, this errors happened due to a bad installing of the theme, sorry! Try again to re-install the theme via FTP way, remove all of the untested plugins, clear all the caches, purge all CDN files if you are using something like this and check the results.
Hope this helps!
What do you mean about “untested plugins”? I use some plugins that work good for example “ad injection” “seo yoast”, must I remove them?
I tried to inactivated all the plugins before installation but the error with td-composer is the same: Fatal error: Call to undefined function rest_url() in /home/xxxx/domains/sitename.it/public_html/wp-content/plugins/td-composer/includes/tdc_main.php on line 84
I don’t find the right way to use this theme and it’s a pity!
The only tested and recommended plugins to use with our theme are these ones:
WP Super Cache- caching plugin
Contact form 7- used to make contact forms
bbPress- forum plugin
BuddyPress- social network plugin
Font Awesome 4 Menus- icon pack, supported in the theme menus
Jetpack- plugin with lots of features *it may slow down your site
WooCommerce- eCommerce solution
WordPress (Yoast) SEO- SEO plugin
Wp User Avatar- Change users avatars
WPML – multilingual plugin
Anything beyond this list is not tested and I cannot say for sure if it will work or not.
