Many times, As I am trying to upload an Image on the website it shows HTTP error. Finally, Work is not going smoothly. Please sort out this problem.
Actually, the theme is consuming all resources or something else, please do something.
Also try these suggestions if there is a problem
– https://docs.presscustomizr.com/article/229-fixing-errors-when-uploading-images-in-wordpress
– http://www.wpbeginner.com/wp-tutorials/how-to-fix-image-upload-issue-in-wordpress/
Theme requirements here – https://forum.tagdiv.com/requirements-for-newspaper/
Hi, Ajay,
Hope your issue is already solved. If not, follow this link. Find the required code under the subtitle “Change Image Editor Library Used by WordPress”.
https://www.wpbeginner.com/wp-tutorials/how-to-fix-the-http-image-upload-error-in-wordpress/
Follow the instructions there carefully.
That solved my issue. But after a future theme update, you may again want to add this code.
Hope this helps.
