Dopo aver aggiornato il tema la home page del tema si è rotta
ho provato a ricostruirla importando un template con WPBakery ma ottengo solamente una serie di codici
Potete vederli da un sito di stage https://stage.sprintnews.it/backup-home-page-non-pubblicare/
che ho creato appositamente
Quale può essere il problema ?
Which version of the theme were you using before updating?
After a theme update, it’s usually necessary to install or update some theme plugins, such as tagDiv Composer, tagDiv Cloud Library (for cloud templates), and tagDiv Standard Pack (for older templates and blocks).
If you’re using the newsletter plugin or the social counter, those plugins should be installed as well.
All theme plugins can be installed, updated, and activated from Newspaper → Plugins – https://forum.tagdiv.com/newspaper-how-to-update-a-plugin/
OK
the problem was the tagDiv Standard Pack which had not been activated after the update
