Hi, I’ve recently had a developer mve my site from one domain to another. After I did this, the visual composer plugin is now giving me the following message:
Hola! Would you like to receive automatic updates and unlock premium support? Please activate your copy of Visual Composer.
I’ve tried to activate it but I get a “no licences found” error message. Is there a way around this?
Thanks for your help.
Hello failmuch,
Please ensure that you are using the latest version of Visual Composer (4.11.2) and Newspaper (6.7.2). Also, please notice that this plugin come bundled with our theme and it is not necessary to buy another license in this regard. Please ignore this message and try to install only the plugins that come bundled with our theme, clear all caches and check the results.
Hi Catalln,
Sorry for the late response.
I have the latest versions of everything.
I can ignore the notice about: “Please activate your copy of Visual Composer.” but the site is not updating automatically? Is this normal?
Also do you suggest not installing any plugins other than those in the bundle whatsoever? So plugins like Yoast, Jetpack, FB pop-up plug in, cannot be used? Or are they not required?
Sorry for all the questions but my page speed has dropped significantly since I updated to Newspaper 7, so I’m trying anything to increase it.
Thanks for your help again!
Hello failmuch,
Please notice the version of the Visual Composer which is required with the latest version of our theme is 4.11.2, so you will have to ignore other related messages to Visual Composer. This type of plugin comes bundled with our theme and it is not necessary to pay nothing for it. As you can see, we have a list with our tested plugins which were tested with our theme and which works as properly, without any conflict. You can use any plugin your want but please notice that we cannot say for sure if it will work 100% with our theme and it will do not cause any problems in theme.
So, if you want to increase your speed optimization, you will have to consult our tutorial here -> https://forum.tagdiv.com/how-to-make-the-site-faster/ because there you will find the important steps which you will have to follow in order to achieve best results. Please notice that this tutorial is addressed only for ADVANCED users and if you are not aware of the steps in this regard, please consider hiring a freelancer/developer to help you because we cannot provide customization services and not speed optimization at the moment, sorry!
