Sorry for posting here but I can’t see where I raise a support ticket??
Have installed theme on my site but the visual composer wouldn’t work – i tracked the problem down to a conflict with MagicMembers plugin – please advise on what I can do to resolve the issue.
Best regards
Dave
Hello davidrattray,
The Visual Composer is fully tested with the theme and seems to work as properly until now, without any issues. Please ensure that you are using the latest version of the theme (Newspaper 7.5) and also, the latest version of required plugins which come bundled with theme packet. The MagicNumbers plugin is not tested with the theme and we have no idea about the theme behaviour with this type of plugin and also, we cannot say for sure if it will work or not with the theme, sorry! My recommendation is to disable all the untested plugins and install only ones which come bundled with the theme and rule out any conflicting plugins. For more information about how you can update the Visual Composer, please consult here -> https://forum.tagdiv.com/how-to-update-visual-composer-plugin/
