problem with Visual Composer plugging
I am trying to install the visual Composer plugging and I received the following:
– El plugin no tiene una cabecera válida (the plugging does not have a valid header) and
-La carpeta ya existe (the file already exist) /home/content/n3pnexwpnas02_data01/24/2912324/html/wp-content/plugins/js_composer/
Fallo en la instalación del plugin. (failed in plugging instalation).
I did not have any problems with the others pluggins.
Please, I appreciate your help.
Thank you,
Francisco
Please make sure that you install the plugin from the Newspaper-tf\plugins path. Before the installing a newer version of the plugin, delete the current one, make sure that in html/wp-content/plugins is no folder called: js_composer then try to install the plugin again.
Let us know how it goes.
HI,
thank you for your quick answer. I have wordpress.com with godaddy. Could that be the problem?
I am not sure that this issue is related with the host provider, so lease make sure you follow the steps indicated in our documentation regarding the VC installation: https://forum.tagdiv.com/how-to-update-visual-composer-plugin/ deactivate all others plugins, clear all caches and test again.
I have done (at least I believe I did) what you have told me to do. However, I keep receiving this message:
Descomprimiendo…
Instalando el plugin…
La carpeta ya existe. /home/content/n3pnexwpnas02_data01/24/2912324/html/wp-content/plugins/js_composer/
Volver a la página de plugins
Please help, I already have used other themes with you and have not found this problems.
thank you,
francisco
Please make sure you also delete the folder containing that name: html/wp-content/plugins/js_composer/. There is probably an empty folder with that name and is creating a conflict . Please access your files via FTP and delete the js composer folder under wp-content/plugins/
  • This reply was modified 10 years by Bogdan B..
Finally through FTP, I resolved the problem.
Thak you,
Francisco
