I have the latest upgrade of the Woocommerce plugin(2.6.14), the Newspaper theme(7.2c) and WP (4.7.2)on my site at; http://www.marketwisetrader.com
I’m having odd results on my Woocommerce Store page. I’ve created several shop/store page one, but each time the vertical spacing can’t be controlled with big vertical spacing between header and page title and top product post. The second VC row of Product Categories also has large ‘un-requested’ vertical spacing. Last, the products are all re-posted a second time below the bottom VC product row !?
Could you advise a fix?
Thanks,
Lon
Hello Leofitz,
I have checked your source page and I noticed that you are using a lot of untested plugins which can interact with the theme core files and cause a lot of unknown issues. Please try to disable all of them, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins. Also, if the problem is still there, please try to make a new clean install from scratch via FTP because this is the surest method in this regard. For more information about this way, please consult here -> https://forum.tagdiv.com/install-via-ftp/
