Problems
Even yesterday morning everything was OK.
Then yesterday evening everything went wrong.
Last plugin update has been done for regenerate-thumbnails.
The only possibility to screen my web page http://www.okultura.cz/WordPress/ was to disable td-composer plugin directory.
I have installed the latest version of Newpaper theme as well as plugins and upload them all in WordPress directories via SFTP.
It did not help at all.
Nothing works now.
Any idea?
Martin
It seems the website is broken at the moment, there are some errors present
– https://www.screencast.com/t/GGlnlIv9ZW
– https://www.screencast.com/t/WNF1Tu0ToMn
I would suggest to contact the hosting provider in this case, ask them to take a look at the issue. This might be server related. Take a look at the theme system status and theme requirements as well
