Problems after updates to 7.4 and visual composer.
Hello. After update to 7.4 and update VC, pictures was hide on site:
http://take.ms/Ed4uU
http://take.ms/fIB2p
http://take.ms/nqTk3
What can i do now?
Please disable all plugins except visual composer, clear cache and reset cnd files if you use it. This is most likely a plugin conflict.
Let us know if you still have trouble with images
Thank you for answer!
But what does it mean clear cache? Is it mean cache in browser or something another?
Where i can find using or not using cnd files?
After that, can i enable plugins whithout problems?
Do you use a plugin for cache? If so check its options and delete all caches. We recommend WP Super Cache in this regard as it’s tested and works fine with our theme: https://forum.tagdiv.com/cache-plugin-install-and-configure/
I assume that you’re not using a cdn service so you don’t need to worry about this. You can check this link for more details in this regard: https://gtmetrix.com/why-use-a-cdn.html
With regard at plugins try to deactivate them all, leave just Visual Composer active then test the site again, it should work properly. Then you can enable back your plugins one bey one and check which one causes the conflict.
