Problems Categories Theme Panel
Hi, I have a problem trying to change options in “Categories” from Theme Panel. When I click one category it never enter and I can’t change the options.
https://ibb.co/Jqdw5ZD
Thanks for the help
Abraham
Hello !
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
It was a memory_limit problem.
Thanks for the help.
