Hi there..!
I am working on my new website http://www.mastermcqs.com and I am facing the following problems in the article display view:
1- I want to change the font size of the Post title ( you see When you open the post it is showing my desired font size, but in the Article Display View at the parent category I am unable to change the size of the font)
2- I want to reduce the distance or margin between the Post Title and the Post content
3- I want to make the divider ( a line to segregate the one post from another) look much bolder and visible between each post in the display as the one I have now is very thin and unnoticeable.
4- I want to give the background to the posts in the display
Note: i have tried other modules in the article display view but this one ( M15) meets my desired result.
I will be really thankful for your help as I am new to this theme
Hello !
For your first question I’ve replied on the other topic:
2. Try this CSS and adjust it as you wish: .td_module_15.post .td-module-meta-info {
margin-bottom: -41px;
3. That will require some custom work and unfortunately we cannot offer due to our support policy: https://forum.tagdiv.com/newspaper-theme-support/
4. Background and other colors can be changed from Theme Panel – Theme Colours
