problems in the home
problems with the block bog grid flex 5 on the homepage after updating
I went back to the previous version of the update fixed problem.
I’m waiting for your clarifications
Unfortunately, we could not recreate this problem, can you please provide us more information about this problem regard big grid flex, some screenshots with the errors, also, if you have a child theme, if you try on a subdomain and only tagDiv plugins are enabled.
The problem recurs when I update. where can i send the screenshot?
https://www.politicamagazine.it/ link conblock bog grid flex 5 not visible.
I look forward to hearing from you urgently
I checked your website and all flex blocks are displaying well.
Did you manage to solve the issue?
If not, then please send a screenshot with your issue and more information in order to help you.
A solution for sending a screenshot is this:
the problem is not solved I have loaded the previous version
Please make sure your wordpress, TagDiv plugins are up to date and try again.
Also, make sure that all the settings are like in our requirements, please follow the guide carefully: https://forum.tagdiv.com/requirements-for-newspaper/
Let us know about your results!
Make sure your WordPress and plugins are up to date, if not make it manually because it was the main issue to everyone.
Sometimes, the issue can be from a plugin conflict, that’s why, please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache(also from your browser) and try again.
If this problem is not solved after that, then we need to take a look and see what happened there.
– admin url and credentials
Our team will take a look!
Viewing 14 posts - 1 through 14 (of 14 total)
