I downloaded the WordPress download and installed and activated the theme. But when selecting the Default Pro theme to add, it doesn’t give me the option to install it without the content. Looking at online videos, this should be as easy as a button, but for me, there is no button or option to not include the content.
Hello !
Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin.
Let us know the results.
maybe this helps – https://paste.pics/7f356356912202d8229478030516ad74
You can see when I hover over the default demo, it says ‘includes content’ with no option for me to install without the content.
Hello !
We need to take a look and see what happened there.
– admin url and credentials
Our team will take a look !
Hello !
