I am having problems saving changes after placing code in Theme Panel, when saving the loading screen remains and does not advance
In similar cases I’ve seen such issues were caused by object caching, or security/firewall configuration. These can interfere with the theme panel saving process. We could take a look and try to help. Please send us an email at contact@tagdiv.com and provide a link to the website and admin login. We will check as soon as possible.
Hello YDL,
Unfortunately we do not know exactly what settings you should do when switch from WP Engine to Cloudflare, you should make sure that you set the recommending settings – https://developers.cloudflare.com/fundamentals/setup/ also please check our guide – https://forum.tagdiv.com/cloudflare-cdn/
