Problems upgrading from 8.8 to 10.3 with a child theme
I followed the instructions but it didn’t go well and I had to downgrade, which took some time and frustration.
The instructions don’t really seem to explain using a child theme but I don’t think that was the issue. I think some blocks were old and didn’t convert or something. I noticed the theme header changed and it kind of looked like there wasn’t a compatible header in the new version…
Did I miss a step or is there a specific way to do this big of an upgrade?
Please make sure you have followed our tutorial in order to update properly as you can see here: https://forum.tagdiv.com/how-to-update-the-theme-2/
Also for child theme there have been some changes made and they can be found in here: https://forum.tagdiv.com/the-child-theme-support-tutorial/
Also please note that we recommend creating a backup before updating and also having the backup done on a staging website.
