problems with ads
Hello ,
I am having a problem with the ads section.
When I click on the arrows, nothing appears
problem
https://ibb.co/WtLxxq0
  • This topic was modified 5 years by alex1234.
Hello !
You seem to do the steps correctly. Please send us a screenshot of your System Status Tab and make sure that all the requirements are met as you can see here: https://forum.tagdiv.com/requirements-for-newspaper/ ; You will have to first start looking for a plugin conflict. please deactivate ALL plugins except tagDiv ones, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
Also you can try and remove and re-install the tagDiv Composer plugin and please send us a link to your website in order to take a look.
Let us know the results.
