Problems with ads using the parallax effect
Hello, Newspaper team.
We are partners with the Teads advertising network, where ads are displayed between paragraphs. Among the video and image campaigns, some are displayed using the parallax/scroller effect and are appearing misaligned and sometimes completely out of frame due to the Newspaper theme. Could you help us try to isolate the theme style so as not to affect the ad style and thus avoid this layout break? I count on your help!
Can you please provide some examples of the code and the link to the website where you have the ads?
Hello.
We are partners with the Teads ad network. Their ad units display parallax formats, and from the feedback I received from support, they’ve already identified the same issue with other partners using WordPress with Newspaper. However, I once tried to display Adsense/Adx banners in Parallax using the Newspaper theme, and the layout appears broken within the iframe, just like Teads. I think if there’s a solution, it should benefit both cases. I’m counting on your support. Thank you.
If using the mentioned ads with the theme options for ads is not working correctly, then the best solution will be to use a dedicated plugin for ads https://www.wpbeginner.com/plugins/what-are-the-best-ad-management-plugins-and-solutions-for-wordpress/
Hi Calin,
First of all, thank you for your support.
Yes, we insert Adsense blocks using the element, but Teads is implemented via a JavaScript tag through the Header script code in the theme settings, which allows the advertising block to be implemented between paragraphs of each post. It’s very likely that the theme’s CSS is somehow interfering with the Teads block’s CSS, causing layout disruption in the parallax effect of campaigns.
If you have any ideas on how to work around this, it would be very helpful.
So if Teads has a JS that needs to be set in the head, then this code should be set in the theme in this place – https://i.imgur.com/jFQ8zFY.png using script tags. Can you please provide some screenshots with the configurations you have now and a link where the ads should be displayed to check the problem that is caused?
