I can’t activate when I enter envato purchase code the button turn indefinitely
When I disable cloudflare it works, same for install demos etc
Can you help I can’t always disable cloudflare to do something.
I setted cloudflare with flexible https and normal settings.
Hi gregzim, please make sure that the cloudflare is set as in our guide from here -> https://forum.tagdiv.com/cloudflare-cdn/ if is set like this it should work properly with our theme.
Let me know the results!
