I believe you mean Visual composer (now WPBakery page builder). The front-end capability of this composer is disabled in our theme, this has always been the case. There could be problems using the WPBakery front-end builder with the theme, or to create posts
– https://forum.tagdiv.com/how-to-use-visual-composer/
Having both WPBakery and the tagDiv composer active could create problems in some cases.
However 500 errors can be caused by insufficient resources, mainly WP-memory. For most users a value of 256M would be enough
Try to increase this if it’s necessary and possible. Contact the hosting provider to modify it for you if needed.
