Problems with design on homepage
I did nothing change on my site https://www.kreditwuerdigkeit.de/ but now I see, the design on the home page is not looking fine. Please take a look.
Thx
Hello darkeye,
I suggest you to enabled the TD Composer and try to recreate the homepage layout with other shortcodes of elements, clear all the caches and check the results. Please use the following tutorial in order to achieve well results. https://forum.tagdiv.com/tagdiv-composer-tutorial-2/
