Problems with desktop home page and mobile
Good morning, it has been a few weeks that the home page of my site, from desktop and from smartphone, is not displaying in correct motion and with the template set up.
This problem did not happen before.
The home page of the site should be seen like this:
https://imgur.com/P7XL50c
Instead, the home page keeps changing and is displayed from desktop like this:
https://imgur.com/0VBxXx1
Also like this:
https://imgur.com/SqSvUP9
It can’t seem to update properly anymore.
From mobile I have the same problem. The home page doesn’t display with the mobile structure I made.
What is the reason for this problem? Can this be fixed?
Thank you very much.
Thomas
Once that you are logged in the website, the problem persists? If the problem is gone, then you need to check the settings from the cache plugin, also from CDN (if you are using).
Also, check if you use object cache.
Whether with site access or without access, the problem remains. I also emptied the chace completely, with no positive result.
This kind of problem has never happened before.
Can you please do a full backup for the website and contact us via email?
If you can, then please provide wp-admin and cPanel access. We check the problem as soon as possible and we’ll try to resolve it. Also, please include the link of this topic so we can easily identify you.
Good morning, being an online magazine doing a back up would really take too much time. However, the problem persists. Especially for desktop view.
The mobile view on the other hand sometimes shows correctly and other times incorrectly.
Can you still check the problem?
We can log in and investigate the problem, but the risk is greater if something breaks on the site.
What we can do is let you know when we start to check the problem. If you agree, please let us knw and please contact us via email at contact@tagdiv.com
the problem on desktop seems to have been solved. But the home page of the site from mobile is still not displayed in the correct way, with the mobile layout I created.
This is causing me a lot of problems and a loss of users from mobile. How can we solve it?
Thank you
For the mobile version do you use a mobile page template? or you use the responsive version? or maybe for some pages you are using the mobile page template and for cloud templates you are using the responsive version?
You can edit both of theme using tagDiv Composer -> https://prnt.sc/uePdV1qglrHJ -> https://i.imgur.com/pGXRtjA.png and responsive version -> https://i.imgur.com/iZdU8bO.png
for the mobile version I use a mobile theme built through your modules. But the display problem appears only in the Home Page.
Hi Tommycreative,
If you are using the mobile theme – https://i.imgur.com/v6xXFSo.png, did you disable it on the homepage where you have the responsive version or the mobile page template?
On the homepage, the mobile theme is not disabled. The problem pops up from time to time. The mobile version of the theme I built is not always displayed.
I see. From what you say, this is happening to do to the cache plugin. The cache plugin you have has mobile cache support? If yes, please be sure that is enabled.
