Problems with mobile theme
I have two problems with the mobile theme.
1. I modified the main page on easa.meout.hu however on mobile page still the blog page opens as main page.
2. Some pages (services, sponsorship, countries) doesn’t work on mobile. Can you help me what would be the problem?
All the best,
Bence
Hello !
The Mobile theme was specially designed for optimization on mobile devices. Unfortunately on mobile theme you cannot do much changes of design. If you want to have the same design as on desktop mode you can achieve that by simply disabling the mobile theme.
Hi Vlad,
Thank you for your reply. My problem is that the pages does not appear on mobile devices at all. So only the footer and the header appears but the page itself is not. I don’t want to changes on design I just want them to appear.
Can you please advise?
Best,
Bence
The mobile version is look like that because you have the mobile theme plugin that provide you a better speed then responsive version of theme, but in order to achieve that speed you’ll need to create a new content for pages because in the most of cases those were made with builders ( tagDiv Composer, WPBakery ) and you need to use only the mobile editor ( you need to set the content for pages in mobile editor and this content will be display on mobile theme)
-> https://www.screencast.com/t/ebUIzt4se
Mobile Theme: Automatic Optimization for Mobile with Newspaper Theme -> https://tagdiv.com/mobile-theme-automatic-optimization-for-mobile-newspaper-theme/
Also for the 3 blocks, you’ll need to have set same feature posts (that have set feature category) -> https://forum.tagdiv.com/featured-posts-2/ -> https://www.screencast.com/t/QsJ6ppY4
If you want the responsive version and amp you should use this opinion -> https://www.screencast.com/t/jZct5ueBqOrb but if you have amp activate on pages you’ll need to create in Mobile editor a content for AMP version of page.
If you do not have the featured category, you’ll need to add some posts in feature category -> https://forum.tagdiv.com/featured-posts-2/ if you do not have this category you can create it, just make sure that you set the category name to be
Featured
Let me know if you have more questions!
Hi Calin,
Thank you for your reply. How should I put the content which was built by tagdiv composer or WP Bakery to the mobile editor, beacuse copy/pasting the code doesnt’t work.
All the best,
Bence
You can not set the content crate with builders in mobile editor, you need to create a new content using only the elements from mobile editor, or if you want to have the responsive version of Newspaper theme you can deactivate the mobile theme.
