Hi, any ideas how I can fix it? ÖÄU is always wrong displayed – here is the website: https://www.deinpekawe.de/
for example “Volvo V90 Cross Country – Der Schwede für’s Abenteuer” should be “[…] Schwede für’s Abenteuer”
Hello meinPeKaWe,
You should load the support language from Theme panel, like this -> https://www.screencast.com/t/crdipFXsU Clear all your caches and check the results.
I already did that, is there maybe a problem because auf the HTTPS / SSL ?
Hello meinPeKaWe,
If you are using the https URL, please try to follow the next steps for your Translations. Try to load your desired translation from panel and then you can see in left corner of your browser, an icon with a shield and then try to Load unsafe scripts, like this -> http://screencast.com/t/aLm2aAFv5
Also, if your problem is still there, please try to translate manually your strings from the theme panel, like this -> http://screencast.com/t/s6bfE5NI6t
I don’t think that the problem is based on the translation. 🙁 And on my chrome is no shield where I can load scripts.
The strange thing is – when I’m logged in , the ÄÖÜ is shown correctly – logged out as a normal visitor there is the problem.
I have made some tests on my live website with these characters and it seems to work as properly, as you can see here -> https://www.screencast.com/t/c8E8b5Vf7d7D Try to disable all untested plugins, if you are using something like this, leave just Visual Composer to active, clear all your caches and install only the plugins that come bundled with the theme packet and rule out any conflicting plugins.
When I delete the catch the website is shown correctly. But after a visit on the website with the new cache the problem is still there. Any ideas for better cache plugins than WP Fastest Cache?
Hello meinPeKaWe,
Please keep in mind that the WP Super Cache is our tested plugin in this regard. For more information in this regard, please check the guide here -> https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hope this helps!
