Problems with my site speed, Help Urgent!
I had run a test on http://gtmetrix.com/ for my site: http://voiceoftrust.in using the Newspaper theme version 6.6.5, and the report shows very low percentage Check: https://gtmetrix.com/reports/voiceoftrust.in/zTS8Y33v (I am using Digital Ocean Cloud Server for this this site) but when I test the demo site it should very high percentage Check: https://gtmetrix.com/reports/demo.tagdiv.com/kLi9K6bo ..? Why is that
Plugins I am using:
Akismet
CloudFlare
Disqus Comment System
Easy Watermark
Hello Dolly
iThemes Security
Jetpack by WordPress.com
NextScripts: Social Networks Auto-Poster
tagDiv Social Counter
Use Google Libraries
Wordfence Security
WP Smush
WP Super Cache
WPBakery Visual Composer
Yoast SEO
I see you are using a CDN Service (which CDN?)as well also your JS,CSS,HTML are minified but mine is not even though I am using Cloudflair CDN.
Please help, I am really struggling to rank my site. Can you please help me optimize the site so that I can lower down the loading time as well.
In order to increase your site speed, you need to follow this guide: https://forum.tagdiv.com/how-to-make-the-site-faster/
you will have to use the speedbooster plugin to move render blocks to footer. Speedbooster will not work with all your plugins as it has a compatibility list in it’s code and some of your plugins are not compatible with it. There is a workaround however. you can remove this code: http://screencast.com/t/RZLIOPUNdqh
As for cdn and minify, we also use cludflare.
I hope this helps.
