Problems with Newspaper.woff
Hi!
How can I speed up the loading of newspaper.woff? It takes me 1 second to load 24KB (see picture).
https://ibb.co/dm71RjK
Our developers reduced the size of this file in the new update as much as they could.
A solution for this issue could be to use some plugins for that, but unfortunately, we don’t have a tested plugin yet to achieve that, so we can’t say if it will work or not. You will have to test and see.
hello Bettina, thanks for your help.
What kind of plugin are you talking about?
I recommend you to use WP Super Cache and with the settings from our guide: https://forum.tagdiv.com/cache-plugin-install-and-configure/
Hope that helps you!
