after the theme update we have another problem of our Site https://autogazette.de
The background colour of the menu/Icon headers of the articles are now black on the mobile site and no longer blue as on the desktop site, Exception is the Resort elektroautos (see Side Bar like “Anzeige”, “Transoformation” etc.)
On the Home-Page is ist correct in Blue:
https://autogazette.de/Homepage Header in Side bar in blue, this ist correct
When I try to make changes under Theme Colors, it does not work because Save Settings does not work (the save icon rotates and rotates without saving)
Furthermore: What are the names of the this items the are now black in the panel? So i can change it?
Thanks in advance, Frank
The First link is for the incorrect version with the black colour: https://autogazette.de/elektroautos/kosten/elektro/elektroautos-produktionskosten-sinken-ab-2027-989422359.html
The settings in the theme panel may be lost (there have been isolated cases), in these cases, after the theme plugins that were previously used are activated, you will have to use a backup for the theme panel -> https://forum.tagdiv.com/import-export-theme-settings/
Also, please check the console when you hit the save button and see if there is an error. With right-click -> inspect -> console -> select the error in the tab network -> preview, you can see the cause https://forum.tagdiv.com/topic/newspaper-theme-panel-settings-are-not-being-saved/
Yes, i have created a sidebar in the widget section, but there are Not colour Settings… And the Settings in the Sidebar are Not responsible for the colours on the maine Site.
IT would BE Kind If you can Tell what IS excactly the Name of the Icons, which is now black, in the Themen Panel Section > Themen colours?
I would like to take a look. Can you please contact us via email at contact@tagdiv.com and provide the wp-admin access? Include the link to the topic in the email.
