Hi!
I have an issue with sidebars.
In the next link: http://infoactivat.com/prats/municipi/butlleti-municipal/
… I use Page builder + page title. In visual composer, I use a row with 2/3 + 1/3 columns (one of the recommended)
In 1/3 column, I place a Widgetised sidebar from visual composer, and I select a sidebar widget, but is not displayed!
I tried to create the same page in this link: http://infoactivat.com/prats/butlleti-test/
… with Default template and sidebar selected (the same than the other one). And this one is displayed.
I most pages of the web, I’ll need to use Visual composer, so… How can I solve this sidebar issue? In every page of the web I need to place a sidebar.
Please… help!
Hello tonitarres,
First of all, please make sure that you have read all of the needed settings which have to be made in order to achieve a Sidebar. Please check here -> https://forum.tagdiv.com/smart-sidebar-2/ -> https://forum.tagdiv.com/sidebars-tutorial/ If the problem is still there, you should make a new clean install from scratch via FTP way, clear all the caches and check the results. Also, if you need more assistance in this case, please send us an email at contact@tagdiv.com with your log-in information (wp-admin) so we can further inspect it closer your setup page.
Now it works fine! Maybe a cache problem…
Thank you very much!
