Problems with yoast seo and Newspaper theme
In my website http://www.culturaenserie.com I have installed Newspaper theme and Yoast SEO. If you go into a post you can see the OpenGraph labels (quite down but inside the body) but facebook can’t load it ¿Why?
This is a post https://www.culturaenserie.com/anne-moliner-se-incorpora-la-tercera-temporada-las-chicas-del-cable.html
Hanks
Support, I have a note OpenGraph also ceased to appear after the latest updates, too, is the Yoast SEO plugin.
I checked my site for some monitoring services, so he began to give them a 403 error after this update.
@CulturaEnSerie
I see no problem with the Facebook share on your website
https://www.screencast.com/t/a8cStdo6J
The Yoast SEO plugin will always add the necessary OG data to the head
https://www.screencast.com/t/PvLCgheTI
@Olya
As long as the Yoast plugin is installed and configured there should be no problem
https://forum.tagdiv.com/facebook-share/
https://kb.yoast.com/kb/why-doesnt-facebook-display-an-image/
If you are experiencing 403 errors on the website, you could contact the hosting provider. There could be an issue with the server.
I tried this method
“Hello,
You can add the rel nofollow a single time and it will affect all social networks where the function I pointed out is used. Simply add
rel= ” nofollow”
like so: https://www.screencast.com/t/ukMdKD57L
Thank you!”
If that doesn’t work, I’ll try your method) Thanks
