For some reason, I couldn’t find the definitive answer to these questions from your documentation:
1) If I only want to use the Adsense site-wide code, do I need to add it to every slot in the Newspaper theme panel’s Ads -section, or only to Analytics/JS code -> Headers section?
2) If I want to add Adsense code by ad slot in addition to the site wide code, is that possible? If yes, does it override the site-wide code in that ad slot?
If you want to use auto ads, then they should be placed in the Theme Panel -> Analytics/Js Codes.
If you need to add the ads manually on every template, then you should add the ads when you edit the post with TagDiv Composer in the element called ” Single Post Content ” in the tab ADS. Documentation here: https://forum.tagdiv.com/article-ads/
Or you can use the element called “Ad box” from TagDiv Composer and there you need to add the ads: https://forum.tagdiv.com/ads-adsense-overview/
If you want to add some auto ads and also ads in some templates, then this is possible and they should display well.
