instead of load more button at the bottom, can you change this to show in pages? like 1,2,3….10
https://jayflyer.com/all-posts/
for excerpts, how do you not show the url?
in the post it’s a video, on excerpt it displays youtube URL which is ugly
The posts loop block has the pagination for number if you want to have
https://forum.tagdiv.com/posts-loop/ -> https://cloud.tagdiv.com/#/single/author/Author/2640
A workaround is to set the subtitle in the excerpt section https://i.imgur.com/SogpdEY.png , which is displayed on the block.
No, it will not affect your meta description of the post -> https://yoast.com/snippet-preview/
