Related Articles issue
I have this article (https://bolojawan.com/nigar-johar-sets-the-bar-high-for-women-in-armed-forces/) and in the bottom section, I have added a related article tab.
Categories of the article are Featured, NewsPop, CultureSocial, Justice and below in related category I have selected this filter (https://snipboard.io/1qdhOJ.jpg) but still it’s showing posts from other categories not from the categories of article
I think that the problem is that when you edit with tagDiv Composer, you want to set the filter for Category template and not single post -> https://i.imgur.com/WgwFeXO.png the category-Current category is use for category templates not post templates, you need to use the Single- Related by category filter, this will display related posts by category.
I have selected Single- Related by category filter now please check this post (https://bolojawan.com/internet-floods-with-hilarious-memes-after-hania-aamir-friendzoned-asim-azhar/)
we have these categories in this post “Featured, Pop Culture,Relationship,Social Media Bites”
but at the end where we have related categories, it’s showing different categories not realted to the post category
Hi malikmubshir,
The Single- Related will display the post related from the same category or tag -> https://i.imgur.com/NucJLmE.png or on classic block -> https://i.imgur.com/XtxujQn.png
Can we add multiple authors in blog post? If yes then please tell me the process
If you are using standard post style and not cloud templates, then you can use our guide for Co-Authors Plus plugin from here -> https://forum.tagdiv.com/adding-multiple-authors-articles/ also the Guest Author plugin can work to, but only with standard post template, with cloud templates will not work.
Hope this will help you!
also, I cannot find this single related posts container (https://snipboard.io/ywx2dQ.jpg)
you can check my screenshot the container is not here (https://snipboard.io/cSVIui.jpg).
I’m using flexbox 1 (https://snipboard.io/PcG8v1.jpg) and added a filter : single “related by category” but it’s not showing the correct categor, for reference you can check this post (https://bolojawan.com/from-asim-bajwa-to-zulfi-bukhari-6-assets-revelations-made-by-imran-khans-cabinet-thatll-make-you-go-whaaaaaat/)
Indeed the related posts container is no longer accessible on tagDiv Composer, these elements are still present in some pro demos like the default single post template, but it’s functions were added in flex block, therefore the results should be the same.
-> https://i.imgur.com/2rBNV5D.png -> https://i.imgur.com/O4G7ItY.png
Therefore in your example if a post has a category that the current post has it will be display on related categories.
An alternative to use the related posts container is to import a single post template from cloud library (Single Post Template 1-20) save that element using the right click -> https://i.imgur.com/40FOQJ7.png in this way you will be able to use it in your current single post template.
There is no option to create a template if I select any of template in this range (Single Post Template 1-20). Please check screenshot is attched https://snipboard.io/mF8UZ0.jpg
I think that you are using a small screen and not a desktop, this should work like this -> https://i.imgur.com/HCGbPMl.png what you can do is to use the resize and make the elements smaller until the button for create template will appear.
If the problem persists, make sure that you do not have a plugin conflict, please deactivate ALL plugins except tagDiv Composer, also if you are using child theme or cache plugin, deactivate them, clear all cache and try again.
I have done that and added that related module but still, it’s showing different categories
Also, check this https://snipboard.io/5dwju3.jpg, I have used both flexbox 1 and related article but it’s showing different categories
The post has 2 categories: Featured, News
but as you can see in the screenshot it’s showing different categories
Hi malikmubshir,
I will try to explain again, the related posts from category will display all the posts that has on of the categories that the current article has -> https://i.imgur.com/asFFNwf.png -> https://i.imgur.com/30RjMdK.jpg -> https://i.imgur.com/fMp9rRM.jpg -> https://i.imgur.com/2bLdRxt.png
If you want you can make a test with a standard post template.
I got what you are saying but my question is: why other categories which are not in the post are also showing? you can also see the screenshot there are some categories which were not in the post but they were showing in the related section.
Take example of screenshots which you have sent: https://imgur.com/asFFNwf – this post have 3 categories “Featured , listicles, news” but in the realted section its showing “News(this category is correct ), Below Featured ( this is not the category), and it missed other 2
I think that there is still something that is not very clear.
In related articles will be display all the posts that has at least one category in common with the current one (in modules/blocks will be display one the first alphabetical category or the one that is set as primer category) for example -> https://i.imgur.com/zPg6V6f.png -> https://i.imgur.com/BASsi1F.jpg -> https://i.imgur.com/UEIYOyg.png -> https://i.imgur.com/n03WFwc.png also if have set a big number for Related Articles and you do not have some many related articles, then will be display after these related articles some articles that are related with current related articles.
