Since few days and after an update, i have this problem:
Warning: A non-numeric value encountered in /homepages/24/d315860610/htdocs/wordpress/wp-content/themes/Newspaper/includes/wp_booster/td_block.php on line 997
appear just before the related articles block on Newspaper.
It disappears when I disable the “More articles box” MORE ARTICLES
Enable / Disable.
How to fix this problem?
Best regards,
Miguel
Maybe you entered something other than a numeric value in the more articles settings
– http://prntscr.com/mdpd6y
You could check that as a first step. Also check if the wp-debug is set to false in the wp-config file – https://forum.tagdiv.com/requirements-for-newspaper/
