I am currently using your theme on my website and I am facing website speed performance issues. My site is loading slower than expected, which is affecting user experience and overall performance scores. I have already tried basic optimization steps like image compression and plugin reduction, but the speed is still not satisfactory.
I request you to please review my website setup and guide me with the best theme settings, optimization options, and recommended configurations to improve loading speed. If there are any specific features, scripts, or modules that should be disabled or adjusted for better performance, please let me know.
Thank you for your support. I am looking forward to your guidance.
What you can do is to use a good cache plugin and a CDN : How to Make the Site Faster
– optimize the images, use a plugin like https://wordpress.org/plugins/ewww-image-optimizer/ and enable the webp format and from the theme, use this option – https://i.imgur.com/6qMAN1H.png
– also, if you are using the WP Rocket, you can check our guide with this plugin https://forum.tagdiv.com/wp-rocket-and-newspaper-theme-optimization-guide/
– in case you are using the option to disable the desktop zone on mobile and the mobile zone on desktop – https://i.imgur.com/TT2slI3.png https://i.imgur.com/jWPKhXS.png
