Hi, I would like to know if there is any way to set the height of the boxes the same so that it looks uniform. https://www.metatraderindicators.com/category/learn-to-trade/
or
https://www.metatraderindicators.com/category/best-mt4-indicators/
The titles take up 1, 2 or 3 lines. I would like to have the boxed 3 lines (for example) so that it looks cleaner.
Thank you,
Trevor
Please, check this topic: https://forum.tagdiv.com/topic/flex-block-1-and-same-blocks-height/
Your element is called “Posts Loop”.
Hope that helps you!
Hi, Sorry to be a pain. I tried this and no luck. Please could you give me some more instructions to make all the boxes in the post loop the same height. Thanks.
eg https://www.metatraderindicators.com/category/learn-to-trade/
