Review Overview Issue
Hello Team,
your theme offers the ability to insert, at the end of each post, a “review overview” featuring scores and a final rating with stars, bars and so on.
The problem is, as seen in this example:
https://www.martialartsexplained.com/three-section-staff/
…that on desktops, all my customizations in terms of bar color, labels and formatting, look fine, but when I switch to the mobile version, looks like all my customizations are lost.
Can you please help me out? Thank you
Fabio
from what I can see now the mobile version and the desktop one are the same, maybe before you had the mobile theme plugin activate.
Also you can customize the pages and cloud templates using tagDiv Composer per each device (dis new option will be apply on flex elements and cloud elements) -> https://i.imgur.com/Z6kmrgg.png
