When I select “Show” in “Show review stars” in modules 1 and 2 in Flex Block 3, no stars show.
Make sure that you have set some reviews on your posts -> https://forum.tagdiv.com/reviews-2/ because only if the post has review can display the reviews in flex block.
Well, of course I have reviews set, on about 1000 reviews, like this: https://jazzjournal.co.uk/2020/05/18/trilok-gurtu-god-is-a-drummer/
You’ll need to enable the reviews on flex elements -> https://i.imgur.com/MIWcRyF.png and make sure that the general option from theme panel is enable -> https://i.imgur.com/g943PSY.png
Let me know if there is still a problem.
Thanks – I had missed the Block Setting and it now works.
However, I have Show Author Name turned on in Meta Info but no authors’ names are showing in category lists, e.g., here – https://jazzjournal.co.uk/category/reviews/audio-reviews/
I am using M6. I notice author name will appear if I use M4, M5, M8 but not in M6 or M7. Is this a bug?
Now, there is no problem with theme, m6 is a small module and the author was remove form it, if you want to display the author on this module, you’ll need to go in theme files wp-content/plugins/td-standard-pack/Newspaper/includes/modules/td_module_6.php and un-comment echo $this->get_author() -> https://i.imgur.com/vflAVRW.png -> https://i.imgur.com/OYUx2b9.png -> https://i.imgur.com/dH3TWbW.png
Hope this will help you!
