is there a way to use breaks within a review summary? I am writing long conclusion. Without breaks reviews turn into a wastelands of text.
Best regards,
Phil
I’m not sure exactly what ‘breaks’ you are referring to, but our review system does not have such an option. You can only use the options presented here: https://forum.tagdiv.com/reviews-2/ Alternatively, you can maybe find a plugin that has such a feature.
Hi Bogdan B.,
I want to insert a new paragraph in my summaries to avoid wastelands of text.
Too bad that this is not possible …
Regards,
Phil
