Review System
Just asking, I am not using any plugin for showing rating as the theme already have this feature.
But I have disabled the rich snippet which is provided by the SEO tool. But Rich Snippet is not showing in Google Search which I filled.
I do not quite understand, I think that you want to show the reviews in google search, if if this than yes, you can use our Reviews functionality from our theme because the Google will be index this post and the stars will be there, in SERP section, as you can see here -> https://www.screencast.com/t/FLdBDtoaYMA
Yes, the post is index but stars are showing as you have shown in your screenshot.
This is how it is showing in google – https://prnt.sc/nxws5f
I have added rating in the post – https://prnt.sc/nxwsbt
Check the posts with the Google structured data tool
– https://search.google.com/structured-data/testing-tool/u/0/
The reviews should show up there if the posts contain them. Why Google decides not to display them up I can’t say. Check some online guides for more information
– http://userguide.getfivestars.com/knowledge-base/3-tips-for-getting-your-review-stars-to-show-in-google-search/
– https://www.ianbrodie.com/get-star-ratings-google-search-results/
Rich results are on the rise -> https://yoast.com/rich-results-everywhere/
Even this post having rating is not showing in google – https://www.androidhire.com/oneplus-5t-review/
How can we add more things in Rating… I want to give the Pros and Cons with affiliate link any product with Rating…
It is possible to add this in inbuild Rating System as these all feature are available on other plugins.
An example I have used other plugin to show these – https://www.androidhire.com/samsung-galaxy-s9-plus-review/
You can try to activate the snippet provided by the SEO tool that you are using, maybe this will solve the problem.
Unfortunately for the moment there is no option to add Pros and Cons with affiliate, sorry! maybe you can use some plugins like this one -> https://wpctrl.com/pros-and-cons-plugin/ or the one that you already tested.
