Reviews and Schema in General post settings
Looking for some clarification of the General post settings, pictured here: https://imgur.com/dKVFJWz
Reviews System – is this to turn on/off the user reviews functionality?
Enable Product Schema on Review – does this apply only to user reviews, or also to our own published reviews?
Enable Article Schema – Can I confirm this should be disabled when Yoast or another SEO plugin is enabled?
We publish our own reviews. Want to ensure our review schema is configured optimally and have no need for user reviews.
  • This topic was modified 2 years by c386.
You can turn it on or off, depending on your needs. Documentation about it is here: https://forum.tagdiv.com/user-reviews/.
That option enabled the product schema for your own published reviews.
Yes, it is also written there.
