Right Sidebar on Nomad Template
I am testing this one in the cloud library:
https://cloud.tagdiv.com/city-guide-for-vienna/?edit_url=null
When I click the row for the main content, its 2/3 + 1/3, but how do you get a sidebar to be there? I can only click one column (the main content) but there’s no where to add to the second column.
To create a sidebar please check https://forum.tagdiv.com/sidebars-tutorial/
This is the problem, “Create the sidebar directly onto the page using a split row and placing elements directly on the page. For more details on how to use the tagDiv Comoser, ”
The row is split but theres no way to grab the right side column.
Please check this video -> https://www.screencast.com/t/buXfL0bXPn
Can you please do this on the template I requested? That’s where the issue is. Not on whatever template you are using. Thank you.
This is the Single Post Template Nomad-> https://i.imgur.com/3mRZBC7.png The same steps are as in the video.
There’s no “empty column” to the right in the cloud template. You are clearly starting from something different than what’s in your library.
Please then select the row and change the layout -> https://i.imgur.com/gmicQop.png
and after you have the empty column.
How can I send you a screenshot? What you have and what I have are totally different. I wish you would import the cloud template to see what’s actually there rather than showing me different versions I don’t have access to.
I installed the prebuilt website Nomad, and the template is like this -> https://i.imgur.com/JM1cPVO.jpg -> https://i.imgur.com/CaUbBU5.jpg maybe after you send me a video I’ll figure out why it doesn’t work for you
