Same header and layout for Frontpage and Category?
Hey guys, I used the tagdiv builder to edit a template i liked, removed some things, changed some and added others and now i got a look that i like in the frontpage. But when i go to categories i get a totally different header, i know how to change the layout of the articles etc but i can’t seem to change the header? How do i do that.
Frontpage: http://www.rekomandime.com
Categories: http://www.rekomandime.com/category/dhurata/
p.s extra question: Is it bad that i linked categories to the menu urls? Like when you click on one of the menus it sends you to that category. Thanks!
edit: wow figured it out the moment i posted. I had a different header selected in theme panel > header > Cloud library template. I don’t know why that was but for some reason it was 2 different headers. It’s solved now!
Follow up question, i am not allowed to edit the categories template with the Edit Template function on the page. It gives me the following answer: “Please select tagDiv Builder Template from the theme panel or set a default template. The current page/post uses a template that is not editable.”
  • This topic was modified 7 years by edmondb.
Hello !
For Categories you will have to set up a Category Template as you can see here: https://forum.tagdiv.com/cloud-library-category-templates/
I hope this is helpfull !
