Same Module Height in a Row
How can I ensure all modules in a row have the same height? I’ve set the excerpt length to a specific number, but the output varies across modules—one displays three sentences while another shows four. Is there a way to define the number of lines instead of character length? Alternatively, is there another approach to maintain consistent module sizes?
In order to make them to look the same size, you’ll need to set an excerpt on title and post content like this -> https://i.imgur.com/o8UQm5B.png
Also, you can set the excerpt on words or letters from theme panel -> https://i.imgur.com/c7Q8ckX.png
Here is a similar topic -> https://forum.tagdiv.com/topic/flex-block-1-and-same-blocks-height/
