In LatinoLosAngeles.com, using Newspaper 11.4.1, the posts are repeated like in a loop. I tried to disable infinite loading single posts but nothing happened. It is the same post repeated.
https://forum.tagdiv.com/infinite-loading-single-posts/
How did I get there? Thank you!
G
Hello G,
From what I investigated, I think you duplicated the row with all the information several times, that’s why the post appears so many times.
So, please edit with tagdiv composer, and delete extra rows.
This can be done with: using the right click on the row icon -> http://prntscr.com/owlyuw -> http://prntscr.com/owlynq or using the drag and drop -> http://prntscr.com/owlz2r or you can simply click on the row and press the delete button from your keyboard.
