Hi Tagdiv.
Thanks for a great theme.
I have found an error that I need help to solve.
I have added a screenshoot here showing the problem:
https://prnt.sc/fc9c5l
As you can see the same posts appear twice in the same box (in this case grid 15, but we have confirmed that it is not depending on the box number).
The posts are only published once.
What can we do to make sure they do not appear more than once per category?
Thanks for helping.
Hello FredAstair,
Here is talking about the duplicate posts which can be avoided if you will use the unique articles or you will add the offsets according to our documentation, like this -> https://forum.tagdiv.com/unique-articles/ -> https://forum.tagdiv.com/offset-feature/
Hi Thanks for your quick reply.
When reading the links you given it seems hat those solutions are for showing block with different categories on the same page, and posts are assigned to both categories.
I don’t think it will help me here. In my case we only display one block with a selection of one category. When using “Load More”, posts from the same category get featured 2 or more times.
Shouldn’t the function be that if we want to display posts from 1 category with “Load More” you should be able to load all posts in the selected category. Now posts are showing 2 or more times…
Hope this helps to understand my issue.
It is in development mode at the moment. How can I send a hidden message to you via this forum?
Now we put it live anyways. The URL is http://www.florida.nu
Hope you can help me find the error.
It also seems to exclude other posts in the same category since the doubletposts is taking their place.
The problems is on many boxes.
Here are 2 examples form the homepage under the BEACHES seaction (stränder)
The first is from “normal”-mode and the other is in incognito-mode, just to make sure it was not a cache problem:
1. https://prnt.sc/ff5roc
2. https://prnt.sc/ff5sce
As you can see in the examples it is not the same posts appearing.
Thanks for helping.
Hello FredAstair,
I have inspected your homepage and I did not saw any duplicated posts, as you can see here -> https://www.screencast.com/t/F9Pe0O9itk Where is the problem? Sorry!
Thanks for helping.
I think we are misunderstanding each other. I do not have problem with showing same posts from different grids.
My print screen examples shows the error if you click on “Load More” from one grid, in eg Beaches (Stränder), there you can see that the same posts appear you twice in from the same grid and category.
Hello FredAstair,
Please read our documentation with more carefully, like this -> https://www.screencast.com/t/VYKmruydo Notice that the Unique Articles has been designed to be used only for static pages and if you are using the load pagination (infinite scroll or load more) you should not activate this feature. Clear all the caches, purge CDN files if you are uisng the CDN system and check the results.
