Save setting does not work
Theme panel – Post Setting – Sharing – Social Network – NAVER
I NAVER activated and then saved. it is displayed. I have NAVER deactivated and saved. after updating, the mark / activated is still there. I’ve tried it many times. also on another computer. no success. I uninstalled and reinstalled tag composer. no change. it remains activated. the save has no success. I sometimes experience that in other settings. it doesn’t always save. it’s a mistake. what can I do?
Hello !
If you’re seeing only NAVER please make this adjustment in the tagdiv composer plugin:
https://www.screencast.com/t/HGX40TlcJgb
Then hit a save in the theme panel and then revert the code back to original, this will make the social icons appear properly again.
Please make sure that you have accomplished all the system requirements as in our documentation here: https://forum.tagdiv.com/requirements-for-newspaper/
