Saved shortcodes will load in tagdiv composer but WILL NOT save.
Hi there,
I’m having trouble getting any of my previously built tagdiv composer shortcodes to Save correctly when building pages. The shortcodes will appear to load in tagdiv composer and tagdiv composer even confirms as saved when I click save, but the shortcodes WILL NOT save.
Is this a known bug in the latest update??
Alastair
There were no other mentions about this until now. I tested saving different elements and rows, there is no problem with that functionality
https://www.screencast.com/t/VE7axKWu
I would suggest that you check the theme system status panel
Insufficient resources could cause such problems. Increase the parameters mentioned in the guide if necessary. Let us know the results.
