Saved shortcuts from demos?
I have installed a demo. I found some block-settings that I like. I right click, type a name for the short-cut and saves.
Then uninsall the demo. Is it true that the short-cuts disappears after the demo i uninstalled? It seems so.
Hello Frydenborg,
Yes, if you will uninstall the demo, all of the theme’s layout will be disabled. You should keep it installed if you like it. Please check here -> https://forum.tagdiv.com/installing-demos/
Hi Catalin. Thanks for your reply. I does not help much to keep the demo, as many of the modules shown are flex block 1, and they can only be recreated manually. Therefore, I hoped that by saving shourtcodes with my own names they would stay,
Hello Frydenborg,
All the page shortcodes can be seen when the page is edited from WordPress, like this -> https://www.screencast.com/t/2ZmIuoRo
